Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1992 Other Ford Models W...
Auto Repair1998 Chevy Truck Heating
Auto Repair2005 Chevy Silverado Ba...
Auto Repair1998 Dodge Stratus R&r ...
Auto Repair2002 Chevy Blazer
Auto Repair1998 Dodge Neon Cold St...
Auto Repair2003 Toyota Matrix Gurg...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Toyota Camry Cold Starting Problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Nov 18, 2008 1:59 pm
By johnmae18, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1999 Toyota Camry 4 cyl Front Wheel Drive Automatic 107000 miles
I have a cold starting problem with this 99 ,4 cyl Camry. Intermittent initially but becoming more of a problem with the weather getting colder. I did basic tune up , cleaned and replaced a battery connection with no improvement. Battery voltage good. Car would start readily with starter fluid and run fine . MIL out ,and PCM has no codes. Warm starts are fine. Tested fuel pump and regulator .Pressure good and held for appropriate time. Changed fuel filter. Changed Coolant Temp sensor and seemed to improve but now colder overnight temps problem is back. Today couldn't start with starter spray. California emission ,so I believe there is no MAF or cold start fuel injector on this car. Now instead of a lean fuel condition on start up ,I'm starting to think this may be an ignition problem. Like I said the car runs great when I can start it ,including good performance on the road.
Find a car repair manual for your Toyota Camry Repair Question.
Posted at Tue Nov 18, 2008 8:59 pm
By ImpalaSS, Moderator
Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2 (154) Give Feedback | Votes: 7
Hello –
We need to make sure you and I are on the same page so I am gonna need a little more info if that’s okay.
First is your Camry a CE, LE, Solara SE or XLE?
Next, a basic tune up….did that include new plugs, plug wires, air filter?
Battery voltage good – did you have a draw test done on it?
Please do me a favor, please go to Auto Zone or O’Reilly’s and for FREE they can pull the codes to the car. I know you did this but have them check once more. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. Very big, while there for FREE also they can bring their tester out and check your battery, alternator and starter.
We need to figure out if it is electrical or fuel related. Pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. Don’t have your hands on any part of the metal!!! If there is no spark, then it is electrical. If you are getting good spark then you need to get a fuel pressure check on the fuel pump to ensure it is putting out okay. You have already said you checked the fuel pressure – do you remember what it was so when you give me the correct model vehicle I can compare it?
Please do the above and let’s take it from there.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Posted at Fri Nov 21, 2008 1:40 pm
It's a LE. Changed plugs wires and plugs .Battery new with new ground to block and frame. Fuel press 46 psi and held for 5 min. Collent temp sens new. Coil pack bank 1 new. Air filter new. Tryed again today to start car, no luck. Turns over fine. Plugs wet with gas after attempt. Checked Crank position sensor for ohms and got a "open"reading. I got a sticker 2 wks ago after I changed the coolent temp sensor.Car ran fine until 1 week later. Mass Insp computer showed no codes also. I use same scanner as Autozone. I'm going to change crank position sens Sat. If this dosen't work I'm really stumped.
Posted at Sat Nov 22, 2008 12:14 am
Hello –
The crank sensor cold should read between 985-1600 ohms of resistance. Also, the car will crank with a bad sensor but it will not start.
I am with you - - change the crank sensor.
Posted at Sat Nov 22, 2008 10:38 pm
By toyotech, Forum Helper
(19) Give Feedback | Votes: 1
Consider the ISC or idle speed control motor. It is connected to the throttle body and sets idle air according to coolant temp. These can gum up causing cold start problems.
Posted at Wed Nov 26, 2008 2:02 pm
Problem solved. It was the crank position sensor. When I took the old one out ,I found the wire had a wear spot and a small break. Started with first turn with new sensor. I still don't know why I didn't a check engine light or a code in the PCM. Thanks for the idea toyotech ,I've run into that before.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
