Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Isuzu Rodeo Questio...
Auto Repair1992 Nissan Sentra Head...
Auto Repair2002 Ford F150 Another ...
Auto Repair2000 Cadillac Catera Ca...
Auto Repair2001 Cadillac Catera
Auto Repair2001 Nissan Sentra Mult...
Auto Repair2001 Chrysler Town And C...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Toyota Camry hesitation
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Sep 07, 2008 1:14 pm
By nselbstaedt, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1999 Toyota Camry 6 cyl Front Wheel Drive Automatic 202000 miles
Last 2 years, engine hesitates most noteably when cold at 66 km/hr, but also at other times and speeds. It is extremely hard to duplicate on command for the technician. I thought it was the transmission and had it rebuild for $3600!!. It did not cure the problem. Two dealers could not properly diagnose or cure the problem. Over $800 already spent on this. There had been no engine codes until last week. Engine lite on for just one or two days and dissappeard. It produced code "P0446. Identification: EVAP system - vent control malfunction. Possible problem area: same as P0441. Identification: EVAP control sytem - incorrect purge flow. Possible problem area:
- open or short in VSV circuit for EVAP
- VSV for EVAP
- Open or short in vapor pressure sensor circuit
- Vapor pressure sensor malfunction
- Open or short in VSV circuit for vapor pressure sensor
- malfunction in VSV for vapor pressure circuit
- vacuum hose blocked, damaged, or disconnected
- charcoal canister malfunction.
The activation of the engine lite did not coincided with any other symptoms. Original symptoms remain the same. Dealer said aftermarket fuel filler cap could be problem. I had it for 1 year, well after symtoms started. Still makes hissing sound when opened for fill-up.
What is your guess of the cause?
Find a car repair manual for your Toyota Camry Repair Question.
Posted at Sun Sep 07, 2008 6:39 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9Reputation: 1006.9 (1007) Give Feedback | Votes: 75
Possible Causes of Engine Hesitation or Stumble:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
