Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1984 Other Subaru Models...
Auto Repair2003 Buick Rendezvous B...
Auto Repair1986 Chevy Silverado Ne...
Auto Repair2001 Jeep Laredo Brake ...
Auto Repair2002 Ford Escape Car Qu...
Auto Repair1988 Ford Bronco Thermo...
Auto Repair1988 Chrysler 5th Avenue...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Toyota 4Runner Miss fire
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 16, 2008 6:37 pm
By dude1888, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1999 Toyota 4Runner 6 cyl Two Wheel Drive Automatic 139000 miles
When I start my 4runner in the morning or when the engine is cold, it runs perfectly and will continue to do so for as long as it is running. But if I stop and turn it off, it missfires in the #1 cyclinder. This is ony afetr it is warm. After about 5-10 mins of driving it will eventualy smooth out until I stop again. The check engine is on and the code is P0171.
Just a recap:
Runs fine when cold and will continue for as long as I drive it
Misses when turned turned off and sit for about 15mins and turn back on, and it really runs kike crap.
Will smooth out after about 5-10 mins of dirving until I turn it off again.
Does this sound like an MAS?
Find a car repair manual for your Toyota 4Runner Repair Question.
Posted at Sun Aug 17, 2008 4:06 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1Reputation: 1007.1 (1007) Give Feedback | Votes: 75
P0171/P0301
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
P0301 check the sparkplug/injector/compression on that cylinder
Posted at Mon Aug 18, 2008 6:45 pm
Now I'm getting a constant #4 missfire, code 0304. I chaanged the MAS, moved the coil, changed the wires changed the plugs. Still the same thing, when I start it when it's cold it will run fine until I shut it off. It won't just start to miss while it's running, it's only after I shut it off. When I start it again it's starts missfiring on #4. this thing is driving crazy.
Posted at Tue Aug 19, 2008 9:44 am
Check the no.4 compression and injector/s Recheck the coil packs.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
