Computer problem
1999 Subaru Outback 4 cyl All Wheel Drive Automatic 104000 miles
Check Engine appears indicating PO 135 Code (Front 02 sensor heater-irregular voltage) only after engine is re-started after initial warm up. When cold and continual usage-No Check Engine Light. Swapped both 02 sensors (Front & rear)(denso brand). Car runs perfect with or without check engine light on.
Some investigations include a potential bad (or shorted) ECM however everything runs just fine. If it was a potential grounding problem, why does check engine light remain off until I shut engine down and immediately re-start while is engine is warm ? Perplexing huh ? Engine is 2.5 litre A/T Would appreciate your thoughts...
Thanks,
Gordon
Venice FL
