Free Car Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Saturn SW2 oil usage
Posted at Fri Sep 04, 2009 7:03 am |
By
roncam47390,
Have Donated |
(21) Give Feedback | Votes: 0 |
Engine Performance problem
1999 Saturn SW2 4 cyl Two Wheel Drive Automatic 150000 miles
Almost overnight my saturn is throwing oil-presumably out the pcv valve connection--throwing 1 or 2 qts out approx every 200 hundred mi--under hood and all engine parts are soaked with oil-pcv has been replaced-vacume in exhaust is good--what could my problem be? |
Find a
car repair manual for your Saturn SW2 Repair Question.
Posted at Fri Oct 09, 2009 7:51 am |
By
saturntech9,
Forum Helper |
   (1779) Give Feedback | Votes: 21 |
sounds like u have too much engine pressure comming up thru ur valve cover.try putting a pressure gauge in ur dipstick hole only thing i can think of that would be throwing oil like that.u could also pull off ur cam cover and look at the inside and see if there is any damage let me know what u find.
louie |
Find a
Posted at Fri Oct 09, 2009 11:00 am |
By
roncam47390,
Have Donated |
Thank you Louie, I will chedk it out and advise you of my findings--Ron |
Find a
Posted at Sun Nov 15, 2009 5:40 am |
By
roncam47390,
Have Donated |
louie my saturan is actually 1995 not a 1999, have had 3 good mechanics look at it, and no answers other than overhaul the engine, is there an air breather on this engine that could be pluged? engine runs great, even when its throwing oil, I am at my witts end, am now considering running keresine through system for a thourough clean out,not sure just how long I can do this without damaging the engine. Ron |
Find a
Posted at Sun Nov 15, 2009 8:53 am |
By
saturntech9,
Forum Helper |
Hey Ron unfornately if u plug the breather u will continue to build pressure in ur engine untill something blows that's why it's called a breather that vents ur excessive internal blow by off so nothing blows up.sorry about that sounds like u need to look into getting ur engine ur engine overhauled as far as the kersone thing I wouldn't explore that idea u would do more harm then good.hope this helps.also donations and feedback greatly appreaciated.
Louie |
Find a
Posted at Sat Nov 21, 2009 7:05 am |
By
roncam47390,
Have Donated |
Louie, thanks again, and for following my problem--i was afraid that an overhaul could still leame me with my problem, That will be my last resort, I didn't mean I would plug the air intake (breather) Thats what I think might be plugged, but I don't understand where it is, to allow me to make sure its clear----Ron |
Find a
Posted at Sat Nov 21, 2009 8:07 am |
By
saturntech9,
Forum Helper |
I have two questions for the first question is in ur first post of ur question u said ur vaccuum in ur exhaust is good what did u mean by that the only thing u test ur exhuast for is back pressure.I asking u to have ur engine tested for blow by which u should have alot of it's where u put the hose for it in ur dipstick tube where u check the oil that would give us more info on ur problem.so could u check that and let me know what u find there.
Louie |
Find a
Posted at Sat Nov 21, 2009 3:58 pm |
By
mhpautos,
Certified 2CarPros Master Technician |
                    (10395) Give Feedback | Votes: 153 |
Hi there,
I think that you need to take a step back and evaluate what you have done to date, firstly as saturntech has stated, there must be a build up of crank case pressure to cause this problem, this cam happen with a blocked PCV, excessive oil in the sump and often engine blow by, this is when engine compression leaks past the piston rings and starts to over pressurize the sump, causing oil saturated air to be forced out the engine seals, and breathers, often you will find that the air filter is covered in oil to some degree, what you first need to do is check the PCV and have a leak down test done as this will be a good indication as to the condition of the lower end,
you can archive the same test results with a wet & dry comp test, this will show any extreme variance in piston ring sealing capability.
mark (mhpautos) |
Find a
Posted at Wed Nov 25, 2009 2:21 pm |
By
roncam47390,
Have Donated |
Mark Thank you for the info--I did get a preasure test done on the oil dipstick tube,as Louie ask for and it came up with no preasure. Just got back from 700 mi trip replaced 6 qts on trip--no noticable smoke out the exhaust. Friend of mine has a 95 saturn having the same problem- we are both drive away drivers, using are Saturns as tow cars. Our cars with hood up and engine running shows no indication of any problems. Thanks again for the info I will see what I can get done with it. Ron |
Find a
Posted at Mon Dec 07, 2009 7:54 am |
By
roncam47390,
Have Donated |
Hey Guys--with all of your comments I have come to the possible conclusion, since I am not using oil,but throwing it. I think possibly that I might have so much sludge build up in engine (which might be shfting on me) causing my problem to be eratic, that I might need to try purging my oil system--do you know who or where I might be able to get this done. A preasure purge and vacume out type procedure. will appreate your toughts. Ron |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
