Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2000 Jeep Cherokee Camsh...
Auto Repair2005 Pontiac Grand Am St...
Auto Repair2002 Pontiac Bonneville ...
Auto Repair1995 Geo Prizm Rubbing N...
Auto Repair1995 Chevy Cavalier Plea...
Auto Repair1993 Chevy S-10 Timing Belt
Auto Repair1996 Chevy Cavalier A/c ...
Auto Repair1984 Chevy Silverado
Auto Repair1995 Buick Riviera 1995 ...
Auto Repair1990 Acura Integra Engin...
Auto Repair1997 Ford F150 Oil Filter
Auto Repair2002 Dodge Neon Check En...
Auto Repair1997 Ford Ranger 3rd Bra...
Auto Repair1999 Ford Explorer Anoyi...
Auto Repair1992 Pontiac Bonneville ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Saab 9-3 repair Question Car won't start
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 16, 2008 1:09 pm
By jhigson, Likes cars!
Give Feedback | Votes: 0
Computer problem
1999 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic 75000 miles
My car was running fine. I parked it for an hour and now it will not start. All the fuses are good, I can smell gas so I don't think thats the issue. A friend thinks it might be the DICE computer under the dash, or possibly the TWICE(?) computer under the drivers seat. We changed the computer under the dash on the passenger side. No luck. Any suggestions??
Find a repair manual for your Saab 9-3 repair Question.
By Advertisment,
Posted at Fri May 16, 2008 1:23 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2 (744) Give Feedback | Votes: 66
I can smell gas so I don't think thats the issue. My question here is -Is it the correct fuel pressure-EFI system are very picky in its pressure.
Try doing below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator/filter and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Posted at Fri May 16, 2008 5:02 pm
I disconnected the direct ignition and got no spark. I also put gas directly into the throttle body. No luck. That is why I think it may be a computer problem that is preventing the coil or plugs in the direct ignition from firing. Thanks for any help you can give me!
Posted at Fri May 16, 2008 8:23 pm
Might wanna double check the ignition discharge module before you replace the computer-
Posted at Sat May 17, 2008 5:17 pm
I'll try that first. Thanks alot
Posted at Wed May 21, 2008 11:35 am
Can you tell me where the ignition discharge module is located in my Saab?
Posted at Wed Jun 11, 2008 6:08 pm
By mnthny4, Likes cars!
your car is fine just replace the engine crank shaft position sensor & you will be fine. if your twice was bad u would get a message on you sid display saying key not accepted & if your dice was bad your light & dash instrutments would not work
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
