Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Pontiac Grand Am Checking transmission fluid
Posted at Mon Dec 17, 2007 7:26 pm |
By
rainyskiez,
New 2Carpros Member |
Give Feedback | Votes: 0 |
Transmission problem
1999 Pontiac Grand Am 6 cyl Wheel Drive Type unknown Automatic 103000 miles
I recently bought a 99 Pontiac Grand Am GT. I have tried to check the transmission fluid and could not find where to do so. I had someone else look and they found it, but when they opened it up there was no dipstick to check it with. Are we missing something? |
| Find out more about your Pontiac Grand Am Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Sun Mar 01, 2009 11:06 am |
By
brian 1,
Certified GM Technician |
(560) Give Feedback | Votes: 16 |
it has no dip stick,here is how you add fluid:Start the engine and allow the engine to idle until the transmission fluid temperature has reached the value specified.
Depress the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the PARK range. Remove the fluid vent cap.
Raise the vehicle on a hoist. The vehicle must be level, with the engine running and the shift lever in the PARK range. Caution: The engine must be running when the transmission fluid fill plug is removed, or excessive fluid loss will occur. Transmission fluid may be hot. Since the actual fluid level is unknown, stand clear when removing the fill plug. Have a container ready to capture any lost fluid. Do not turn the engine off with the fill plug removed, as you can be injured by hot transmission fluid being expelled out of the oil fill opening.
Remove the transmission oil level control plug. this trans only has a fluid vent cap that you can unscrew to add fluid. also PLEASE START A NEW THREAD NEXT TIME,THIS THREAD IS ALMOST 3 YEARS OLD. post back with any other questions. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
