Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
I have a 1999 Plymouth Voyager and the car doesn't want to start. It cranks, looks like will start but is not starting. I think that may be sort of fuse or relay (if such thing exist and is responsible with the car starting) or the fuel pump. Is the fuel pump located in the gas tank? If not there where it is? How right or wrong I am here? Thanks for your help!
firstly check the underhood fuse/relay box theres a list of fuses and relays on the lid .. check fuel pump fuse .. and while someone turns key in ignition is fuel pump relay clicking .. you sjhould be able to hear/feel it ??
Underhood Fuses
A Power Distribution Center is located in the engine compartment, near the battery. A label identifying the components and circuits is located on the underside of the cover.
Underhood Fuses
Well..today when I try to start the car...started!..after running for a while, i spot the can and, when try to start again, same thing: didn't want to start..Now i am so confused: it will be the relay or the fuel pump?
is your MIL showing on the dash ?? have the car read for fault codes ... easiest way for you to check whether your getting fuel .. crank the engine over a few times .. remove a spark plug if its wet and smells of fuel your getting fuel from pump ....
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
