Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
the van will not start without my OBD II scanner attached to it . I am curious as to why this is. Is the scanner bypassing something in the PCM to make it start. What should I be looking for and how do I fix it. Any help is much appreciated.
I had this happen to me on a ford vehicle .. took it to ford dealer to have the ECU read by them ? as you probably know OBD II readers have their limitations ? in laymans terms ford said the ECU had become clogged with info ? they cleared all faults and vehicle ran fine again ?? owner of vehicle was expecting to replace ECU/PCM ? after all a computer is a computer ?? hopefully yours could be the same situation ?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
