Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1999 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 84000 miles
i have a 99 plymoth breeze, which started to give me a problem. at first it only started accelerating at 2000 rpms then it stopped moving all together. the check engine light came on only after trying to get it to a safe place in limp mode. now when i turn it on it makes a weird scrape noise. want to know what to start with or what it sounds like i have to replace
I am guessing the check engine light will give you transmission codes. You can start checking both input and output speed sensors, located on top of the transmission. Also you may test your transmission control module making sure it is working properly. Most of the time, the car makes horrendous sounds when it is running on limp mode.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
