1999 Other Suzuki Models Loosing Engine Coolant / No Thermos
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1999 Other Suzuki Models 4 cyl Two Wheel Drive Manual 208000 miles
i removed my thermostat valve a month ago, now i am facing a problem that the coolant is finished every morning i start the car. there is no leak any where. I opened the radiator and got it checked as well all pipes every thing, there is no leak. now my car is getting hot every time i drive because of no coolant. coolant level drops even if i drive for as long as 20 km. there are no bubbles in the radiator opening so the gasket is fine and i got it replaced last week
please help
The coolant has to be leaking internally or externally... so get a cooling system pressure test done first as this will locate any small external coolant leak.
thank you mark, but in pakistan we dont have such facilities as a coolant system pressure check. and if there is any it will be hard to find. can u please advise an alternate
thanks
there is no other alternative, you can just let the car get up to full temp and allow the natural pressure to build, that is the only other way to check, you will have to look very carefully at all hoses seals and gaskets, don't forget the welsh plugs as well.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
