1999 Other Mercedes Benz Models crank shaft sensor
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Other Mercedes Benz Models V8 All Wheel Drive Automatic 158000 miles
Vehicle cranks and runs but shuts off as soon as engine reaches operating temperature. Will not crank again until motor cools. Is this the crank shaft sensor gone bad?
This is a common problem with the 112/113 engines. The crank position sensors are a common replaced part for these symptoms. In our shop we usually will see a code for the cps or sometimes no code at all. It is a good bet that the crank sensor is the culprit.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
