Engine Mechanical problem
1999 Other Fiat Models 4 cyl Front Wheel Drive Manual 82000 miles
hi there, just replaced head gasket on my fiat punto,
pior to that the engine was miss fireing, however after warm up say 2 miles ok. replaced plug leads, now when i start up ok run upto 3 miles when temp reachednormal engine starts miss fire on one or more plugs. sounds like to much fuel ?. is there a fuel sensor do i need to replace the sensor or ecu and if so where do i locate it, and the engine does not overheat please can you help as i am stuck, manythanks regards margaret
