Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Drive Train Axles Bearings problem
1999 Oldsmobile Bravada 6 cyl Four Wheel Drive Automatic
WHEN I TRY TO MAKE A LEFT OR RIGHT TURN IT GRIPS AND DON,T WANT TO TURN. SOMETHING IS BINDING . I WAS TOLD IT WAS STUCK IN 4X4. NOT SURE WHATS THE PROBLEM
Find a car repair manual for your Oldsmobile Bravada Repair Question.
The Bravada is full time 4X4. It sounds like you may have a bad coupler in the transfer case or the ABS is telling the system that the tires are slipping. That would apply the system and make the 4 wheel act that way.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
