Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Dodge Neon Cold St...
Auto Repair2003 Toyota Matrix Gurg...
Auto Repair2002 Suzuki Grand Vitara...
Auto Repair1997 Isuzu Hombre
Auto Repair1997 Other Plymouth Mode...
Auto Repair2000 Oldsmobile Silhouet...
Auto Repair2002 Hyundai Elantra Id...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Oldsmobile Alero OIL PUMP
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Oct 17, 2008 10:30 am
By elektricman, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1999 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
I have a 1999 olds alero, 3.4 liter, 6 cylinder. I am not getting any oil pressure. So far I replaced the oil pump in the oil pan. The hex drive shaft which drives the oil pump does not look worn. I turned over the engine to see if the oil pump 'drive' shaft turns. It does not turn. The oil pump 'drive' shaft is firmly engaged with the 'upper' drive gear. I even tried to turn the oil pump 'drive' shaft with a socket & ratchet to see if the drive gear was stripped. It didn't turn. WHAT COULD BE THE PROBLEM?
John
Find a car repair manual for your Oldsmobile Alero Repair Question.
Posted at Fri Oct 17, 2008 12:17 pm
By ImpalaSS, Moderator
Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2Reputation: 154.2 (154) Give Feedback | Votes: 7
Hello John
I have attached a pic showing the drive gear to the camshaft. Is it possible with the oil pump out and extension removed to look up to see as someone turns the crankshaft by hand to see if the drive gear is moving with the camshaft?
If I understand, you were not getting oil pressure but the engine was still running and you shut it off when you saw there was not pressure I assume.
If this did not happen and the engine stopped running, my thought there is the timing chain is broken if the top of the engine is not turning and the bottom is. Thus the cam is not turning even though the engine is spinning.
Here is the probable cause for no oil pressure. If you notice the 2nd to the last item is a worn or poorly machined camshaft. You are to replace the camshaft which I would think the gear is attached to it.
Let us know if this helps.
Low or No Oil Pressure
The following conditions may cause low or no oil pressure:
• Low oil level Fill to the full mark on the oil level indicator.
• Incorrect or malfunctioning oil pressure switch Replace the oil pressure switch.
• Incorrect or malfunctioning oil pressure gauge Replace the oil pressure gauge.
• Improper oil viscosity or diluted oil
• Install oil of proper viscosity for expected temperature.
• Install new oil if the oil is diluted.
• A worn or dirty oil pump Clean or replace the oil pump.
• A plugged oil filter Replace the oil filter.
• A loose or plugged oil pickup screen Replace the oil pickup screen.
• A hole in the oil pickup tube Replace the oil pickup tube.
• Excessive bearing clearance Replace the bearings.
• Cracked, porous, or plugged oil gallery Repair or replace the engine block.
• Missing or improperly installed gallery plugs Install or repair the plugs as needed.
• A stuck pressure regulator valve
• Inspect the pressure regulator valve for sticking in the bore.
• Inspect the bore for scoring and burrs.
• A worn or poorly machined camshaft Replace the camshaft.
• Worn valve guides Repair the valve guides as needed.Oil Pressure Testing
Thanks for the donation.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
