Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1999 Nissan Altima 4 cyl Front Wheel Drive Automatic 130000 miles
When applying and releasing brake pedal, I hear a
click, that seems to be coming from the shift selector
lever. You can also hear a squeaking nose as you
apply brakes that was not happening until the click
noise started. Thank you.
The pedal pivot may need lubing, and if you have a transmission selector safety lock out, this is triggered by the pressure on the brake pedal, have this checked for operation & adjustment as well.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
