Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Nissan Altima 4 cyl Front Wheel Drive Automatic 120,00 miles
FRONT WHEELS ARE LOCKED TO THE LEFT.IGNITION SWITCH WILL NOT TURN TO START SEEMS LIKE IT IS THE SWITCH.STEERING WHEEL WILL NOT UNLOCK.
The lock cylinder might be jammed. There should be a retaining pin underneath the steering column (small hole). Insert an ice pick or very small screwdriver in this hole. Insert the ignition key and turn ignition to on position and then press in on the screwdriver. Twist the lock and pull away from the steering column.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
