Electrical problem
1999 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
I have a 1999 mitsubishi eclipse 2.0L automatic non turbo.I replaced the head gasket because it overheated.I have 125psi per cylinder 45 to 50psi fuel pressure and good spark on all cylinder but I have a missfire on #2 and #4 injectors. I have power to the injectors but ground is not coming from the ECM. I replace the ECM and I still have the problem. Does anyone knows what triggers the ECM to send the ground signal. Please I need some help. Thanks
