Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Mercury Sable Heat...
Auto Repair2002 Nissan Altima Losi...
Auto Repair1990 Toyota Camry Faile...
Auto Repair1997 Jeep Cherokee
Auto Repair2002 Chevy Tahoe Return...
Auto Repair1996 Mercury Sable Emis...
Auto Repair1997 Dodge Neon
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Mercury Sable Engine is heating and water is leaking f
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 19, 2008 8:16 am
By prasanth, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1999 Mercury Sable 6 cyl Four Wheel Drive Automatic 62000 miles
I drive Mercury Sable, 1999, and it has about 62000 miles on it. When I use A/C for long time, water has been leaking from the coolant but only when it is parked. I thought it was because of the long A/C usage. However, recently I drove from New York to Dallas, Tx. Water is leaking from coolant heavily every time I stopped. According to a mechanics advise, as I was on the way, I kept the coolant cap very loose, poured water in it every two hours. Everyt time I stopped the water was leaking, but no smoke. The engine heat indicator is showing very normal all through. We reached Dallas four days back, and yesterday as I was on the road, suddenly the accelator was down, I pulled the car aside and stopped the engine. Then the engine did not start. I towed it to mechanic, he said ignition coil to be replaced. He did, and charged $350. When I went to pick up, he said, head gasket is blown and estimated $1700. And then he said water pipe leak, but he is going to do this free. What could be te problem? Was it a gasket blow at all? or is that water pipe leak? I never had water in my oil? and I never had engine starting problem? in fact it was very quick? Do they have to put the ignition coil and charge me $350? Appreciate your kind concern and happy to award $25 award to technician, if I am informed where I could have saved money. Thank you
Find a car repair manual for your Mercury Sable Repair Question.
Posted at Sat Jul 19, 2008 8:53 am
By Docfixit, Moderator
Reputation: 143.6Reputation: 143.6Reputation: 143.6Reputation: 143.6Reputation: 143.6Reputation: 143.6Reputation: 143.6 (144) Give Feedback | Votes: 5
Cooling fans may have not been comming on for some time. The long trip with it boiling over not good. The guy that told you to keep cap loose was not correct because pressure raises boiling point.
The loss of power and no start is classic head gasket failure. As for the coil that is a little high and wrong you should not need to pay as now he says gasket is blown. The $1700 is about right . I would find a shop that is A.S.E.Certified to be sure you are getting a trained tech and good diaignosis.
Good Luck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
