Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Nissan Maxima Fuel
Auto Repair1991 Nissan Maxima Fuel ...
Auto Repair1994 Nissan Maxima Filters
Auto Repair1992 Nissan Maxima Noise...
Auto Repair2000 Nissan Maxima Front...
Auto Repair2005 Audi A6 Car Can't D...
Auto Repair1992 Nissan Maxima Chugg...
Auto Repair2007 Toyota Corolla Fuild
Auto Repair1996 Nissan Maxima Car C...
Auto Repair2004 Nissan Maxima Cars ...
Auto Repair1985 Ford Bronco I'm Goi...
Auto Repair1995 Nissan Maxima Radia...
Auto Repair1998 Mercury Marquis Car...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Lincoln Continental Service engine soon light and oddi
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 16, 2008 10:16 pm
By bryantsel, Tech level 1
Reputation: 26.8 (27) Give Feedback | Votes: 0
Computer problem
1999 Lincoln Continental V8 Front Wheel Drive Automatic 128000 miles
Hey,
On my 99 Continental I had the service engine light come on. In the manual it says engine has run out of fuel, poor fuel quality, and improperly installed gas cap. The light came on with a quarter of a tank of gas so maybe rule out bad fuel. I have not let the car run out of fuel. Finally, I have checked the gas cap and it is secured. Any advice? I have not given it three driving cycles, however, like the manual says. Though, the oddity I have been having with the fuel is when pumping gas the pump keeps getting shut off (The gas station pump, not the fuel pump). This is a huge pain because the pumps (At different stations) are always kicked off and I have to keep releasing the handle. Any reason why the car is kicking off the gas pump and would it have any correlation with the service engine light?
Thanks,
Bryant Selko
Find a repair manual for your Lincoln Continental Repair Question.
By Advertisment,
Posted at Sat May 17, 2008 3:13 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3Reputation: 533.3 (533) Give Feedback | Votes: 44
No correlation, mine does the same thing, pull the nozzle, or rubber hood back and it will fill OK, inside the fill door is the recommecnded fuel, most lincolns require premium gas, if you use others, it may cause your problem, post the code if you can, it would be of some help!
Posted at Sat May 17, 2008 7:33 am
The error I am getting with the light is a solid Service Engine Soon. Not blinking at any point. Is that what you were asking?
Thanks,
Bryant Selko
Posted at Sat May 17, 2008 8:27 am
Sort of, but not quite...I would like to get the code number it can be scanned at Autozone, they do it free, write it down and post the result here...it will most likly be a "P" code such as P0301 or something...
Posted at Sat May 17, 2008 11:57 am
Hey,
I got the code read, it came up with a P0174 and P0171 with "System too lean (Blank 1)," and "System too lean (Blank 2)." ...I have no idea what makes a car lean...but I hope it taste better then lean hamburger, lol. I did, however, reset the codes. I have no idea if I should have done that or not.
Thanks
Bryant Selko
Posted at Sat May 17, 2008 12:08 pm
Something else I would like to throw in is the car has felt like it is slightly shaking every now and then, and rarely (Twice this year) moderately shaking. Shaking being defined as an abnormal motion form side to side.
Bryant
Posted at Sun May 18, 2008 4:15 am
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! Or a fuel pump problem...
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Posted at Sun May 18, 2008 9:28 am
Actually just had the fuel pump replaced because the car was not starting easily. So the vacuum line is just that small area near that sensor, as in the video?
Bryant
Posted at Mon May 19, 2008 8:57 am
Found the problem. A very big hole in the vacume hose boot going into the engine. Had to replace the whole thing, $20 so not too bad and a minute of time.
Thanks
Bryant Selko
Posted at Mon May 19, 2008 9:44 am
Your welcome.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
