Transmission problem
1999 Jeep Wrangler 6 cyl Four Wheel Drive Manual 117000 miles
I have been told two different things on my jeep, this is a closed system and I can't bleed the slave cylinder because it is inside the bell housing and I have been told you can bleed the slave even if it is inside bell housing because there is a valve sticking out, I can't find this. Can this master cylinder and slave cylinder be bled or do they both have to be replaced and do you have to drop the trans to replace them. Please help, jeep won't move, when I try to crank it just jumps forward
