Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2005 Chevy Silverado Ba...
Auto Repair1998 Dodge Stratus R&r ...
Auto Repair2002 Chevy Blazer
Auto Repair1998 Dodge Neon Cold St...
Auto Repair2003 Toyota Matrix Gurg...
Auto Repair2002 Suzuki Grand Vitara...
Auto Repair1997 Isuzu Hombre
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Jeep Laredo Radiator Cooling Fan
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Nov 14, 2008 6:50 pm
By Bryan S., Have Donated
Give Feedback | Votes: 0
Electrical problem
1999 Jeep Laredo 6 cyl Two Wheel Drive Automatic 96,000 miles
I just replaced the radiator in my 1999 Jeep Grand Cherokee. After everything was put together all was fine except the cooling fan would not run. I turned on the AC and let it heat up to operating temp and still wouldn't work. I checked the voltage coming from the relay connector to the fan and had 12.8 volts. I bypassed the connectors and still it would not operate. I ran it to the battery and it ran fine. What could be the problem?
Find a car repair manual for your Jeep Laredo Repair Question.
Posted at Fri Nov 14, 2008 7:15 pm
By jnovack, Moderator
Reputation: 128.1Reputation: 128.1Reputation: 128.1Reputation: 128.1Reputation: 128.1Reputation: 128.1 (128) Give Feedback | Votes: 5
check the Cooling Fan Control (Electric Fan Thermostat) also check the Coolant Temperature Sensor theyare what makes the fan turn on
Posted at Sat Nov 15, 2008 5:14 am
I have looked at the relay in the PCM, the relay under the passenger side headlight, but I have not heard of the electric fan thermostat. Where is it located? Also, if
it has 12+ volts at the fan connector what else is required for it to come on?
Posted at Sat Nov 15, 2008 10:51 am
ok now do you have 2 fans 1 electric and 1 mechanical or do you have just the electric fan reason asking you can put a mechanical fan on it
Posted at Sat Nov 15, 2008 12:07 pm
Electric fan only. I checked the leads from the relay and had 12.8 volts. When I hooked them to the fan leads I had no voltage. If there was a short in the fan would it cause the relay to break the voltage?
Posted at Sat Nov 15, 2008 1:48 pm
check the continuity in the wires going from the relay to the fan you may have a break in one of the wires and not letting the current through
Posted at Sat Nov 15, 2008 8:28 pm
Attached alligator clip leads to relay leads and had 12.6 volts. Took off connectors and directly wired relay leads to fan. No voltage. Hot wired fan to battery and it runs.
Something (Relay?) is getting kicked when the fan is connected to the relay leads.
Posted at Sun Nov 16, 2008 5:15 pm
you said you changed the relay correct? if so check to see if you are getting voltage in wires from relay to fan
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
