Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Hyundai Sonata Alternator removal from car
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 23, 2008 11:33 am
By UDZRV12, Have Donated
Give Feedback | Votes: 0
Electrical problem
1999 Hyundai Sonata 6 cyl Two Wheel Drive Automatic 85000 miles
I just had a rebuilt alt installed by mechanic. The car never made it home that night. No idiot light, no charge. Night drive depleted battery. Mech on 2 week vacation and I need the car. Am doing troubleshooting today after battery charge. At startup alt output at 14.2v at battery,OK, after 2min of idle voltage drops to battery voltage 12.2v, no charge. Diodes in fuse box check OK. All fuses check OK. Where do I look? I decided to remove alt and take in for a test. Everything is loose, and disconnected. HOW DO I GET IT OUT?
Find a car repair manual for your Hyundai Sonata Repair Question.
Posted at Sat Aug 23, 2008 2:35 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
Remove the distributor cap. Remove power steering pressure hose nut. Loosen belt tensioner, remove belt. Remove timing belt cover cap and timing belt upper cover, remove the alternator.
Posted at Sat Aug 23, 2008 3:27 pm
Sorry I need more info. This car has no dist cap. what is in my way is the CV shaft Does it come out through wheel well, behind motor?
Posted at Sat Aug 23, 2008 3:35 pm
This info comes from Mitchell, normally they get it from the manufacturer, if the info in the manual is wrong, the best I can do is ask you to post a clear picture I can look at to help figure it out.
Posted at Mon Aug 25, 2008 7:12 pm
I gave up trying to remove the alt. Looks like after the CV shaft is removed, the cross member needs to drop a few inches. Too much for me. What about trouble shooting the intermittent charge, does this model 1999 V6 Sonata have an external regulator, how can I analyze intermittent charging. With fully charged battery the alt output is 14.2v for 8 minutes the 12.6(battery), then after a few minutes it may begin to charge. If I turn on loads, lights fan AC, it drops to 12.6v and never comes back even if the loads are turned off. Challenging.
Posted at Wed Aug 27, 2008 9:52 am
By KHLow2008, Moderator
Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2 (179) Give Feedback | Votes: 13
If crank pulley is equipped with dynamic damper, check if it is faulty.
Posted at Wed Aug 27, 2008 6:19 pm
I don't get it. what will vibration supression have to do with charging?
Posted at Thu Aug 28, 2008 5:34 am
If the dampers are detached and freewheeling on the main pulley, the belting would be running at a much lower rpm thus lower/no charging rate.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
