Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1999 Honda Passport 6 cyl Four Wheel Drive Automatic 197000 miles
When I turn the ignition on, it sounds like it wants to start, but the "kick" that turns the engine on does not take place. What do you think the problem is?
check fuses
check battery terminals (clean and tighten )
check and make sure battery full and in good health!!
check the starter
locate the starter check terminals make sure they clean and tight
check for power on the big terminal all the time
S small terminal has power when u turn the ignition switch to start
and if so starter no good
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
