Car Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Honda Civic valve noise after changing timing belt.
Posted at Sat Jul 04, 2009 10:19 am |
By
DK711,
Have Donated |
Give Feedback | Votes: 0 |
Noises problem
1999 Honda Civic 4 cyl Front Wheel Drive Automatic 130000 miles
I recently changed my timing belt and I had installed it wrong by one belt notch, thinking that I had it at TDC. Well I tried to start it and ofcourse it didn't sound right. So I took it off and installed it again this time making sure it was right. It runs good now but I have some valve noise when the engine is under some load. Could you tell me what this could be and what I can do to fix it? Also if I need to fix it right away or would it be ok for a while? |
Find a
car repair manual for your Honda Civic Repair Question.
Posted at Sat Jul 04, 2009 12:58 pm |
By
F4I_guy,
Moderator |
           (1161) Give Feedback | Votes: 19 |
Don't assume it's valve noise.
What does the noise sounds like? Are you SURE it was only off by one tooth?
If you are sure it's valve noise, do a compression test to see if you bent a valve because you do have an interference engine. If that checks out, do a valve adjustment. |
Find a
Posted at Sun Jul 05, 2009 11:26 am |
By
DK711,
Have Donated |
You know the sound when an engine has alot of miles on it and you hear that valve noise, well thats what it sounds like. Im certain it was off one tooth because thats how much I needed to move it. I will do a compression test and see if anything comes up. What do you mean by interference engine? Thanks for your help on this. I appreciate it. |
Find a
Posted at Sun Jul 05, 2009 1:25 pm |
By
merlin2021,
Certified 2CarPros Master Technician |
                            (2867) Give Feedback | Votes: 97 |
Intereferance engines will hit piston to valve if the belt breaks, or is installed wrong, this may bend the valve, or break the guide, or both. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
