Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1999 GMC Yukon V8 Four Wheel Drive Automatic 112000 miles
My lights are new the fuses are good and I am getting power to the harness but the lights do not come on when the pedal is pushed down why
next make sure the plunger on the switch is being moved when the pedal is moved, does pushing on switch by hand change anything? check and makesure the third light isnt burned out and recheck for brakes.
you may want to check for damage in the harness inm cab next since all 3 dont work.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
