Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Chevy Avalanche Sp...
Auto Repair1997 Ford Explorer 97 E...
Auto Repair1999 Ford Taurus Possib...
Auto Repair2003 Chevy Impala Squeak
Auto Repair2005 Chevy Impala Head ...
Auto Repair1999 Gmc Savana Wont St...
Auto Repair1990 Honda Accord Warni...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 GMC Sonoma Cylinder 2 misfire & no heat
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Oct 23, 2008 12:20 pm
By JBiggs82, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1999 GMC Sonoma 4 cyl Two Wheel Drive Automatic 200000 miles
Recently replaced head gasket and had cylinder head machined down (was warped). Also recently replaced radiator, thermostat, water pump, and lower radiator hose.
Everything was running great for a few weeks after replacing the head gasket and radiator (along with lower hose). Then one day it starting running very sluggish until you drive down the road for a ways (maybe 3-4 miles), then runs just fine....maybe still a bit sluggish at idle. The most likely scenario I came up with was contaminated fuel. Ran fuel injector cleaner through each tank (currently on my 4th tank of fuel since then), still running sluggish on intial startup until warmed up. DTC code was reading several hundred instances of cylinder 2 misfire, along with a few (5-10 misfires or so) on each of the other cylinders. The engine requires you to hold down the gas pedal in order to start it up in the morning. Then runs sluggish for awhile, randomly "catching" more power intermittently. Possible air seepage somewhere around intake...not 100%positive on that though. Vacuum line? Can't be spark plugs (changed those with head gasket).
Not sure if this is related but the turck also operates at appropriate temperature (190-210) for the first 10 minutes of driving or so, then the temperature guage drops to less than 100. Also I have NO HEAT. Brrrrr... I live in Michigan! Recently replaced radiator, coolant, lower radiator hose, thermostat, and water pump. Did a backflush of the heater core today and everything flows fine, except when engine is warm, only the inlet heater hose is hot.....outlet is cold. Backflush and forward flush with garden hose and adapter showed free flowing passage.
What is causing my lack of heat, and why might I be misfiring on cylinder 2? I'll take all possibilities here.
Also, tested Engine Coolant Temperature sensor, works perfectly. New thermostat stuck open??? I am completely overwhelmed here. Please HELP!!
Find a car repair manual for your GMC Sonoma Repair Question.
Posted at Thu Oct 23, 2008 12:36 pm
By rasmataz, Certified 2CarPros Master Technician
(15) Give Feedback | Votes: 78
Hi JBiggs82 andwelcome to 2carpros
Misfire at no.2 cyl-check the sparkplug/compression/injector for this cylinder
Lack of heat
When no or low heater output is not due to a blower problem (plenty of air coming out of the ducts but the air isn't hot), the list of possible causes include:
Blocked circulation through the heater core - due to either sediment in the core or a defective heater control valve. Feel the heater inlet and outlet hoses while the engine is idling and warm, and the heater temperature control is on hot. The hose will not feel hot on the heater side of the valve if the valve is shut. The outlet hose will also not be hot.
With cable-operated control valves, check the cable for sticking, slipping (loose mounting bracket) or misadjustment. With valves that are vacuum operated, there should be no vacuum to the valve when the heater is on (except for those that are normally closed and need vacuum to open). Someone may have misrouted a vacuum hose.
With electronic heater control valves, check for voltage at the valve. It should have voltage when the temperature controls are set for maximum heat. If the solenoid fails to move when voltage is applied, it is defective and needs to be replaced.
If the heater core appears to be plugged, the inlet hose may feel hot up to the core but the outlet hose will remain cool. Reverse-flushing the core (forcing water into the heater outlet pipe with a garden hose) can sometimes open up a blockage, but usually the core will have to be removed for cleaning or replacement.
Air pockets in the heater core also can interfere with proper coolant circulation. It's akin to losing the prime with a siphon pump. Air pockets form when the coolant level is low or when the cooling system is not properly filled after draining.
Low coolant level - usually the result of overheating or a coolant leak. A low coolant level can starve the heater resulting in little or no heat output. To check the level, pay no attention to the overflow reservoir. Shut the engine off, wait 20 minutes or so for the engine to cool, then carefully open the radiator cap. Allow any residual pressure to vent itself completely before removing the cap. If the coolant level inside the radiator is low, adding coolant won't fix the problem if there's a leak. Inspect the water pump, hose connections, radiator and engine for coolant leaks. Also pressure-test the cooling system and radiator cap to check for internal coolant leaks due to a bad head gasket or cracks in the cylinder head. Check the pressure rating on the cap to see that it's correct for the application, and carefully inspect the cap's gasket and spring. Replace the cap if it can't hold its rated pressure or has the wrong pressure rating for the application.
Cooling system neglect can allow internal corrosion to eat small holes in the heater core or where the pipes are soldered to the end tank. Leaks also can be caused by sediment circulating in the cooling system. Sediment is abrasive and will literally wear holes in the heater core.
A leaky core will often drip coolant into the passenger compartment (don't confuse this with water condensation that may be coming from the A/C evaporator). Leaks also can develop from fatigue cracks in the inlet and outlet pipes. This is caused by flexing of the heater hoses from engine torque and/or vibration.
Adding sealer to the cooling system may provide a temporary fix, but the long-term cure is to replace the heater core.
Defective or missing thermostat that allows the engine to run too cool. Maintaining the correct engine operating temperature (usually 200 to 220 degrees F.) is essential not only for good heater output but also for good fuel mileage and proper operation of various emissions control functions. If the temperature gauge on the dash reads low, the engine is slow to warm up or you can feel coolant rushing through the upper radiator hose when the engine is cold started, the thermostat is stuck open (or missing) and needs to be replaced. Be sure to install a thermostat that's rated at the same temperature as the original (usually 195 degrees on late-model cars).
A weak water pump that fails to circulate an adequate amount of coolant to the heater. This problem also will cause the engine to overheat. If the problem isn't due to a slipping drive belt, the pump probably has an eroded or separated impeller
Posted at Thu Oct 23, 2008 1:02 pm
I have ne srk plugs, all gapped appropriately. The compression is great now that the cylinder head has been machined down nice and flat and put back with a new gasket and new head bolts.
As for checking the injector, how on earth do you do that? I also forgot to mention I have a DTC code for defective cat converter.
Also, on the heater core issue, I noticed that your reply message was a standardized response to issues relating to this. I read the exact same post in another forum word-for-word. If you go back and read what I originally wrote, I said that I had already performed a backflush of the heater core, and everything flows nicely and clean. I have no coolant leaks anywhere, I have a brand new water pump and a brand new radiator, and also a brand new thermostat.
And as for the heater core "valve" you refer to, I don't have access to this without removing my entire dashboard, correct? The only thing I have is an inlet hose and an outlet hose both going into the firewall. The inlet was warm, the outlet was cold. But I don't get it...water flows *easily" through the heater core (as proven when I performed the backflush). I usually have heat when I first turn on the heater inside the cab, but then it goes away within seconds. Also just noticed that with the heater blowing on the floor (cold air of course)...it suddenly switched and started coming out of the dash vents, then back to the floor.
Any additional help you have is greatly appreciated. Thank you!
Jeff
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
