Auto Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1999 GMC Sierra Need help with GMC suburban acceleration pr
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Wed Apr 30, 2008 11:04 am |
By
rnjsranch,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1999 GMC Sierra V8 Four Wheel Drive Automatic 135k miles
I have replaced air filter,all 4 o2 sensors ,TPS, fuel filter is good replaced fuel pump 6wks ago and CAT's are both fine. Starts fine, after driving 5-10 minutes or incline when i accelerate it sputters and backfires which sounds like it is coming from passenger side under hood loose power .Then turn engine off restart and runs just fine for again another 5-10 minutes?? I keep getting the P0171,P0174,P0131 codes have redone codes several times at idle and while driving? If anyone has any suggestions besides taking to a shop i am all ears here?
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your GMC Sierra Repair Question. |
Posted at Wed Apr 30, 2008 2:24 pm |
By
rnjsranch,
Have Donated |
i clean the maf i changed the fuel filter the old was hard to blow threw could the maf still be bad the truck will idle fine but when you put your foot in the gas the truck will back fire and sputter turn the truck off the problem is gone for a little bit then same problem is back
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Wed Apr 30, 2008 6:19 pm |
By
blackop555,
Certified 2CarPros Master Technician |
      (136) Give Feedback | Votes: 27 |
it may, and it may not. depends on the severity but i wouldnt go replace it yet, id have a shop test it first.
could be ignition system related, check timing, dont know about plugs, coil, plug wires, ignition module since it doesnt have to cool down before restarting and running good.
also check for vaccum leaks which will probably cause your codes, especially after the MAF sensor.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Wed Apr 30, 2008 7:24 pm |
By
rnjsranch,
Have Donated |
sorry to keep bothering you but one more question i will be changing the cap rotor and plugs and wires could a timming chain cause this thanks for all your help
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Sat May 03, 2008 7:35 pm |
By
rnjsranch,
Have Donated |
i found the problem it was a fuel pump i want to thank you guys for all your help keep helping people this is great site
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
