Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1999 GMC Sierra Low idle, running rich, revs but no go in o
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Fri Nov 21, 2008 6:10 pm |
By
coley25,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1999 GMC Sierra V8 Four Wheel Drive Automatic 273000 miles
Sorry guys-you have the wife of a very frustrated guy here. I have to ask, as he's at his wit's end, so please bear with me...
Bought the truck 2 weeks ago-(5.9L Sierra 2500), and on the way home up a hill in overdrive it revved out when his foot was on the pedal, but no acceleration, almost like it's in neutral.
When started, it idles low (500rpm) then when put in gear it wants to stall. It accelerates OK otherwise, but is running rich.
Code reader said P0122, so he changed the TPS, & a blown 40amp fuse, cleaned battery terminals, changed plugs and wires, fuel filter, IAC, cleaned the throttle body, MAF, and EGR. He's checked for a vacuum leak, and voltage to TPS.
When he disconnects the TPS and IAC and starts it, it idles just fine for a few minutes, then idles low again.
Thanks,
Coley
| Find a
car repair manual for your GMC Sierra Repair Question. |
Posted at Sat Nov 22, 2008 6:38 pm |
By
coley25,
Have Donated |
He tried it, still the same. (BTW, the truck is a 2500 SLT, not a Sierra, if it makes a difference.)
Any other ideas?
| Find a
Posted at Sun Nov 23, 2008 7:58 am |
By
coley25,
Have Donated |
Sorry, had been reading way too many posts when I first asked the question-you do have the right info, promise! He's doing a compression test today. He's in the industry, so he's, talked to a few people, but this one is really stumping him. He's tried all I've suggested on this site, (after reading till my eyes are crossed) and now the only other thing I could think of was maybe the 02 sensor? I wonder if he has 2 separate problems, the low idle (no black smoke, just smells rich) and the overdrive revving out like that. I had a similar problem with OD in my truck, but it was the catalytic converter, no idle problems.
I was thinking fuel pump or pressure, but he said they had it on the big scanner at work (forget the exact name) and it would have checked the fuel pressure, and that no codes came up after changing the TPS. And still that low idle, wants to stall in gear, and we are still confused.
He called the guy he bought it from, and he said he never had a problem (of couurse) except for one time when it was really hot out, it was running rough.
Only other thing I can think to tell you is that is has that engine tick, which I've read is common.
Any ideas? (His are to burn the ***thing)
| Find a
Posted at Sun Nov 23, 2008 7:59 am |
By
coley25,
Have Donated |
I believe it was 5 volts.
| Find a
Posted at Sun Nov 23, 2008 4:02 pm |
By
coley25,
Have Donated |
Fuel pressure reg. is OK, and compression test was OK.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
