Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2007 Toyota Corolla Car...
Auto Repair1999 Plymouth Breeze
Auto Repair1999 Plymouth Breeze Id...
Auto Repair2001 Nissan Sentra Mult...
Auto Repair2004 Chevy Cavalier Rea...
Auto Repair2001 Nissan Sentra Over...
Auto Repair1992 Nissan Sentra Head...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 GMC Jimmy
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 13, 2008 7:19 am
By kevin masserant, Likes cars!
Give Feedback | Votes: 0
Transmission problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic
i have recently rewired a 99 gmc jimmy at the power dist. block and at the pcm. I used the mitchall manner diagrams. i have cheked all the wires three times and i'm still having problems with the torqueconverter locking up as soon as it shifts out of 1st gear going into 2nd. the speed sensor calls for 5volts and i am only getting 0.64volts. i have replaced the pcm and still have the same problem.i have scanned it for troble codes but come up with nothing. the "check engine" light gos off like it is supossed to. the engine runs fine.where does this problem sound like it may start
Find a car repair manual for your GMC Jimmy Repair Question.
Posted at Tue Oct 14, 2008 9:49 am
By Jacobandnickolas, Moderator
Reputation: 114Reputation: 114Reputation: 114Reputation: 114Reputation: 114Reputation: 114 (114) Give Feedback | Votes: 5
Hi:
It sounds like the speed sensor is bad, or you have a broken wire. Did you replace the speed sensor?
Posted at Wed Oct 15, 2008 6:20 am
Hi Joe
This is the guy with the 99 gmc jimmy again. I have put my scan tool (Actron Elite Auto Scanner CP9185) it seems to communicate with all systems and it tells me no faults detected. I have also checked the speed with the scanner and it matches the speedometer with scan tool in drive mode. I got 4.0-5.0 volts at the VSS I would think that the VSS checks out to be ok. The wiring harness has been taking out of the jimmy and checked with a continuity by digtial meter and couldn;t find any broken or crossed wires. every thing in the jimmy works, except for this shifting problem. Any ideas about pusle width module but it seems like a DTC code would make the light come on. Im out of ideas. PLEASE HELP.
Posted at Wed Oct 15, 2008 5:58 pm
Hi:
I reviewed your original question and it indicates that you're only getting 0.64 volts and should be getting 5 volts. Is that in or out? Is there any way you find a different one just to try? Not being there with you is making this even harder, but I truly question if that is what is causing your problem. Regardless, I don't want you to spend the money and it not fix the problem.
Let me know what you think and get back to me. While you think of that, I will contact some of the other moderators and get their opinion. WE WILL FIGURE THIS OUT!
Posted at Thu Oct 16, 2008 9:18 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7 (684) Give Feedback | Votes: 80
Which sensor exactly is only getting .64 volts?
Are you positive which ever sensor it is, is located at the correct pin at the PCM? If the wire checks out ok, that is the first thing that comes to mind....especially if the PCM has been changed
Posted at Thu Oct 16, 2008 9:59 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5Reputation: 1005.5 (1005) Give Feedback | Votes: 75
Disconnect the TCC solenoid and see what happens-also test the brake switch and the TPS sensor
Posted at Thu Oct 16, 2008 10:39 am
By jnovack, Moderator
Reputation: 97.2Reputation: 97.2Reputation: 97.2Reputation: 97.2Reputation: 97.2 (97) Give Feedback | Votes: 3
the Transmission Control Solenoid has alot to do with Torque Converter lock up can you test this and let us know what you get from test
Posted at Sat Oct 18, 2008 12:42 pm
Hi Joe
Here I am back with the same 99 Gmc Jimmy with the same shifting problem. I have sent the Jimmy to Amco transimissons & he put it on his trans scanner on it and he told me that mechanically the tranny was ok. I have checked the vss, iss and the oss and all three sensors will give me ac signal back to the pcm. with the rear tires off the ground in drive running about 15 mph i have checked for 5 volts at the vss and also the pcm plug and all i have is .64 volts so i jumped 5 volts from the reference wire off of the mass air flow sensor to the vss and still same problem i have been told by one person that it calls for 5 volts and another person said it called for 12 volts. What voltage does the vss call for and is there any reason for the pcm to only give me .64 volts on the vss signal wire. The tps seems to be operating smoothly on the scanner i also put a new brake switch on and still no difference. All circuts to each of these sensors have convity back to the pcm. I am ready to shoot this jimmy and get it over with. Do you have any more ideas if you do please help iam running out of ideas on this truck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
