Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Buick Regal Fuel L...
Auto Repair1998 Ford F150 4x4 Problem
Auto Repair1999 Ford F150 Heater N...
Auto Repair2002 Ford Windstar Deloris
Auto Repair1994 Ford Ranger Bleedi...
Auto Repair1998 Chrysler Sebring C...
Auto Repair2001 Pontiac Grand Prix ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 GMC Jimmy Truck intermittently cranks but does not sta
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Sep 28, 2008 8:53 am
By sonnysmustang, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic 76000 miles
I have had a very intermittent starting problem with my Jimmy for a couple of years which has recently become more frequent. It doesn't matter if the truck is hot or cold. There doesn't seem to be anything common except that it just suddenly decides to start up just before the battery goes completely dead from cranking. It was suggested that it could be the fuel pump relay which I swapped with the AC relay during the last occurence but it had no effect. A few tries later, it just started again.
Then the next day, a short local trip, a five minute shutdown and it happened again. Just a note: it seems to catch for a second and the tach goes to about 1000rpm's and just shuts down as if I had just shut off the key. Any troubleshooting advice would be appreciated.
Find a car repair manual for your GMC Jimmy Repair Question.
Posted at Sun Sep 28, 2008 8:59 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2Reputation: 1009.2 (1009) Give Feedback | Votes: 75
Check the fuel pressure to rule out the fuel pump and then comeback
Posted at Mon Sep 29, 2008 3:48 pm
I checked the fuel pressure tonight. With the key in the on position the pressure is 62psi. I also tested it running. It's 55psi.
I have no running problems. Just intermittent starting.
I also borrowed a Snap=On code reader and found no stored engine codes.
Posted at Mon Sep 29, 2008 4:27 pm
Next time it shutsdown immediately look for spark-no spark check the cam and crank sensors.
Posted at Mon Sep 29, 2008 5:35 pm
Wouldn't a malfunctioning cam or crank sensor generate a code? I'm not sure. Just asking.
Posted at Mon Sep 29, 2008 5:48 pm
I'm sorry. I forgot to ask. How do I check the cam and crank sensors short of replacing them if their failure doesn't generate a computer error code. I'm trying to avoid the costly "parts swapping" method of troubleshooting.
Posted at Tue Sep 30, 2008 6:06 am
Sometimes a sensor/s failure wil not generate a code. Check the computer with and w/o a code/s, you never know what will show up.
I gave you both just in case it has no spark-causing the intermittent start-could be very well be the computer that's acting up-who knows
Check its resistances/gap
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
