Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic 145000 miles
i have fuel to the throtle body but will not start. if i put fuel in the housing it runs till fuel is gone. any suggestions
What pressure and volume of fuel do you have? What is the fuel pressure key on engine off - engine running - pressure drop when you shut the engine off. When was the fuel filter changed last?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
