Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic 118.00 miles
I have checked the the gear oil in front axle the level is fine and the gear oil looks great. The service fouor wheel drive light is on. How do you turn it off
That light means there is a problem. NOT that the oil needs checking. You need to pull the trouble codes and see what you have. Then you have a starting point.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
