Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic 90,000 miles
When you first start the van in the morning it doesn't want to stay running until it warms up. I suspect a sticky choke but not sure what to do. about it. I was also thinking it may do with a fuel filter. An help would be great.
what you should be checking instead would be the engine temperature sensor aka coolant temperature sensor.
also could be the intake air temperature sensor, idle air control or if you have a heated air intake for cold starts if thats not working properly it may not be warming up as designed.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
