Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 130,00 miles
i've been having trouble with my car the last couple weeks. every now and again 1 of the fuses under the hood would blow and take out dash lights and tail lights and when shutting the car off headlights stay on. not it is every time you try and turn headlight on it blows a fuse. we replaced the headlight switch and its made no difference, i also removed the fuse the went to the daytime driving lights because they would only flicker like a strobe light until you turn regular headlights on. but now everytime we do it takes out dash and tail lights but nothing else. do you have any suggestions for me? i was told it may be a relay and auto parts store wants 75 dollars for it. i dont want to spend that kind of money unless i know thats what the problem is. thank you for your help.
rainwaters
thank you for your help on where to start looking for wiring problem. i've checked all the bulbs and there doesn't seem to be any problems with those. and have checked wiring as well and didn't find any loose or broken connections. anymore info would be greatly appreciated! thank you!
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
