Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Dodge Dakota Heate...
Auto Repair1993 Mercury Sable Turn...
Auto Repair2003 Mercedes Benz S320 ...
Auto Repair1995 Ford Explorer Heat...
Auto Repair1997 Other Plymouth Mode...
Auto Repair1998 Plymouth Voyager C...
Auto Repair2005 Ford Explorer Alte...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Ford Taurus Code P0172 and P0175 Runs rich bank 1 and
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Aug 06, 2008 9:11 pm
By HPhillips, Have Donated
Give Feedback | Votes: 0
Computer problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 105000 miles
This problem is driving me crazy. I overhauled the engine but it took me over a year. Now it runs fine, compression is over 150 on all cylinders, but this code won't go away and I can't pass emissions to get a new tag! As I said it runs fine and no black smoke from the exhaust. The manifold vacuum is a bit low at 15 but I cannot find a leak. Sometimes I get an ignition misfire code but it may be be because it runs so rich. Plugs are all black though #2 is slightly less so. I thought I had found the problem because though I have voltage to the mass airflow sensor it reads higher while running than the manual says it should, only slightly lower than when running. So I had a bright idea and I separated the hose between the MAF so that some of the air bypassed the sensor. I did not get the codes this way while running in the driveway. Also the maniflold vacuum came up to just under 16. I am guessing it was still a bit rich or maybe went lean but not enough to set off the computer. I am guessing the IAC has to crack open a bit more causing the low manifold vacuum. I cannot find any component that measures the vacuum pressure so I think I am done looking for leaks. Could the computer have lost the correct settings or something?
Oh, I replaced the MAF but it does the same exact thing. But when I replaced it, there was a warning that the warranty was void if I did not reuse a rubber seal on the connector. Apparently that went missing during the rebuild somehow. Can this be because of a stupid dust seal? I hate to drag it into a shop and have them do a $100 plus diagnostic and then find out it is because of a $5 part.
BTW is there an OBD tool that will tell me how rich lean, and the tables etc without costing an arm and a leg? I guess I could spare a few fingers.
Find a car repair manual for your Ford Taurus Repair Question.
Posted at Wed Aug 06, 2008 9:23 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4Reputation: 1009.4 (1009) Give Feedback | Votes: 75
OBD2 P0172 & P0175. Is a typical symptoms of an engine that is running rich (too much fuel, not enough air) are poor fuel economy, elevated emissions (Carbon monoxide or CO), and engine may have rough idle or surge condition.
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
HTH-Good Luck
Posted at Wed Aug 06, 2008 11:35 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
Also the only sensor that uses vacuum to operate is the MAP...I agree on all the others Raz listed so test pressure like this....
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
You can rent the test gauge at Autozone.
Posted at Thu Aug 07, 2008 4:07 am
I replaced the fuel regulator first thing, forgot about that. I cannot actually check the pressure as this uses a small fitting and the tester won't fit between it and the alternator with the adaptor. There is no MAP on this car. How do you check for a plugged fuel return line, is that the one the regulator is on? I don't think the manual says which is the return. Also I had to install the camshaft position timing by eyeball as I could not find the special too. Could that have anything to do with this? Also the airfilter is new, and just to be sure I tested it with the MAF disconnected from the air box. But if I disconnect the MAF from the intake hose I don't get the run rich codes. I put some fuel injector cleaner in the tank, I suppose the old fuel could have clogged them up, but wouldn't that cause it to run lean not rich? Also both the ambient and coolant temperature sensors are working and correct.
Also if the fuel pressure is too high, how does the computer manage to correct the rich condition when the MAF is bypassed?
Posted at Thu Aug 07, 2008 11:28 am
The pcm uses an average if the maf is unplugged, so your problem may be the MAF if it clears up when you disconnect it...There is an adapter For Fords and other cars that don't even have test ports, it's installed at the filter. The line coming out of the FPR is the return, test it by blowing into it, and removing the gas cap, listen at the tank..check for kinks in the line. If you don't show CPS codes, you may have nailed it pretty close by eye!
Posted at Thu Aug 07, 2008 5:48 pm
I did not unplug the MAF, rather I simply pulled the hose off between the MAF and the throttle body. The hose will push itself right back on so I stuck a screwdriver between the hose and the MAF so that some of the air bypassed it. After that I REPLACED the MAF, but the new one acts just like the old one so back to square one. I am thinking that maybe the reference table memory got lost or scrambled while the computer was down without power for a year. Thats another reason I don't think its the pressure regulator or plugged return line, because the system was able to correct the problem if less air went through the MAF.
I worked as a mechanic for a while but that was in the 70's. What is a FPR? I doubt I can afford any special diagnostic tools as I am not a hobbyist nor a professional, I just like to have a project once in a while.
Posted at Thu Aug 07, 2008 11:32 pm
FPR=Fuel pressure regulator.
Posted at Fri Aug 08, 2008 3:53 am
It occured what FPR was right after shutting the computer down LOL. I will check the return or fuel pressure this weekend. If that doesn't work I think I wll take it to NAPA auto repair for an $85 diagnostic Monday.
Posted at Fri Aug 08, 2008 12:21 pm
If the diagnostic is just code reading, try Autozone or advance auto they do it free.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
