Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Ford Taurus car runs rough at frist start up of the da
Posted at Sat Nov 07, 2009 6:58 am |
By
joenunya,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
When its 45 degrees and below, at first start up of the day, car runs really rough and always comes up as cylindor 1 misfire. After the car warms up, it runs well the remainder of the day. |
Find a
car repair manual for your Ford Taurus Repair Question.
Posted at Sat Nov 07, 2009 7:11 am |
By
merlin2021,
Certified 2CarPros Master Technician |
                            (2867) Give Feedback | Votes: 97 |
Have a look at the plug, plug wire and injector on that #1 cylinder, when was your last tune up? Get a noid light and unplg the injector, plug the noid light in and see if it flashes as the car is running. if it does, plug injector back in, start car, listen or feel the injector for clicking. If you asr handy enough, you can swap that injector into a different cylinder and see if the misfire moves with it, also a compression test wouldnt hurt. engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
http://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one! Also check the injectors with an ohm meter, should be 11-18 ohms, if not, replace it. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
