Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
By fouled, is the plug black? Wet? Melted electrode? Anything abnormal about it? Did you change all plugs or just #8? . Is it a single coil pack, or coil on plug system? Were the plug wires if coil pack all changed? Coil on plug, where the Boots under the coils changed? And can you feel the injector clicking with the engine running? You may need a fuel pressure and injector leakdown test.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
