Engine Mechanical problem
1999 Ford Escort 4 cyl Front Wheel Drive 85000 miles
I have a 99 Escort that is shredding timing belts. I'm told the crank shaft is moving and causing the belt to walk up the pulley and shredding it. Is there a fix without using a short block? If so what and how do I get it done?
