Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Ford Escort NO REVERSE
Posted at Thu Nov 05, 2009 2:43 pm |
By
fourx4,
Have Donated |
Give Feedback | Votes: 0 |
Transmission problem
1999 Ford Escort Two Wheel Drive Automatic
Install a used Transmission in a 1999 escort shifted Ok for one day now has no reverse.
code set are PO750 PO713 PO755 PO760 P1506 |
Find a
car repair manual for your Ford Escort Repair Question.
Posted at Fri Nov 06, 2009 1:54 am |
By
Dave H,
Certified 2CarPros Technician |
                       (2412) Give Feedback | Votes: 42 |
Hello .. thanks for the donation .. much appreciated
You could have low fluid level, a faulty/wrong Transimission range switch fitted or it could be a fault inside the transmission !!
No Reverse, Forward Gears Okay
Fluid level and condition, shift linkage, low line pressure, valve body, incorrectly tightened valve body bolts (cross-leaks), 1-2 shift valve, Neutral-Reverse accumulator, pump assembly, reverse clutch and low/reverse clutch.
hope this helps
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
