Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Ford Escort front wheel bearing installation and remov
Posted at Thu Feb 05, 2009 11:01 am |
By
fontana,
Have Donated |
(42) Give Feedback | Votes: 0 |
Drive Train Axles Bearings problem
1999 Ford Escort 4 cyl Front Wheel Drive Automatic 117000 miles
need to replace front bearing. Saw a tool kit at harbor frieght that claims to be able to remove and replace bearings with out taking spindle strut mount, etc. off -thus saving huge time and alignment. Does this type of tool work well? what would be the directions for using this type of tool. PS. i have never removed wheel bearings b4. |
| Find out more about your Ford Escort Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Thu Feb 05, 2009 11:11 am |
By
racefan966,
Certified ASE Technician |
      (3286) Give Feedback | Votes: 49 |
Ok first don't buy that tool it will not do what you need it to do. I would call around and find if one of your local parts store will rent one or find a shop that has a press and will do that part for you.
First you need to remove the axle nut from the center of the wheel. Then loosen the lug nuts and jack up the car and put on jack stands and reomove the front wheel. Now you remove the brakes and rotor and then loosen the lower ball joint and tie rod end and loosen the lower strut mount and remove the steering knuckle and take it to a shop and have them press the old bearing out and the new one in and then put it all back together and have it aligned when your done. Here are a couple of pic hope this helps.
- Donate Here |
Posted at Thu Feb 05, 2009 10:23 pm |
By
Zackman,
2CarPros Level 6 |
(453) Give Feedback | Votes: 8 |
While it may be worthwhile to have this tool handy if you will be doing a lot of front wheel bearings. Have you considered tool rental? How about this one?
You can go to your local CSK/O'Reilly stores (Checker, Schuck, Kragen or O'Reilly) and ask them for Rental Tool Kit #27, part number 648741, SKU 8454878. You pay a deposit (which varies by localities), you can have the tool for 2 days, then return it for your deposit back (keep your receipt, though). As they won't return it without your original receipt. |
- Donate Here |
Posted at Wed Feb 11, 2009 3:13 am |
By
fontana,
Have Donated |
how does the tool work? do you just have to take off the axle nut and then just pull out the bearing somehow? Or do you have to remove the drive axle from the hub first somehow?
Is removing and replacing the wheel bearing using this tool easy to do or might i experience difficulty/problems? I'm using a borrowed garage and i cant leave the car there very easily if something goes wrong. |
- Donate Here |
Posted at Wed Feb 11, 2009 10:41 am |
By
racefan966,
It works best with air tools as with hand tools it is very hard to get that bearing to move. It is in there very tight and then the road grime and such can make that thing take several hundred pounds to get it started. It is much easier if you take it to a shop and have them do the pressing part on the bearing and you do all the work of taking it apart and putting it back together. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
