REAR BRAKE SHOES
Removal (Contour & Mystique)
Raise and support vehicle. Remove wheel assembly, and remove drum retainers. To release brake strut and quadrant, remove plug in backing plate and insert screwdriver between brake strut and knurled quadrant. Push screwdriver forward to separate brake strut and knurled quadrant. Remove brake drum.
Remove brake shoe hold-down springs, pins, and brake shoe return springs. See Fig. 2 . Remove brake shoes and parking brake return spring. Disconnect brake strut and quadrant from brake shoe. Remove parking brake cable from cable anchor on trailing brake shoe.
Installation
Use high temperature grease to lubricate brake shoe contact pads. Connect parking brake cable to parking brake cable anchor on trailing brake shoe. Install trailing brake shoes on backing plate, and engage brake strut and quadrant. Install parking brake return spring,
****brake shoe hold-down spring pin, and brake shoe hold-down spring. ****
Position leading brake shoe, and install hold-down spring pin and hold-down spring. Install brake shoe return springs. Adjust brake shoes. See REAR BRAKE SHOES under ADJUSTMENTS. To complete installation, reverse removal procedure. Bleed brakes (if necessary). See BLEEDING BRAKE SYSTEM .
