Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1999 Dodge Ram V8 Two Wheel Drive Automatic 131750 miles
Engine very seldom reaches normal operating temp nor will the heater get beyond warm in winter, even after 20+ miles. The only time it will reach normal temp is when idling for awhile with an outside temp of 95+ degrees. I have changed the thermostate 3 times, radiator flushed twice,water pump and finally the fan clutch.
Hi Bholl
Is the thermostat a 195 degree? Most like a cool running engine your's seem like an ice maker. You make need to block air flow to radiator as an option.
Let me know
Thanks for donation
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
