Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Dodge Neon 4 cyl Front Wheel Drive Automatic 109000 miles
i just replaced the fuel pump with a brand new one, but my fuel pump fuse keeps blowing perodicaly. the service engine light comes on sometimes but not all the time. it gives no warning before it blows. i also checked all of the wires for shorts, couldn't find any. could it be my oxygen sensor? what should i do.
A possible problem could be you power wire is pinched somewhere causing it to touch a ground which will blow the fuse. Have you checked the wires for this?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
