Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1999 Dodge Neon 4 cyl Front Wheel Drive Manual
how am i supposed to remove and reinstall the valves on a dohc neon ive tried evrey tool offer by every auto parts store (which is very limited) ive asked many people who supposedly have automotive experiance i have resorted to using a old scholl c- clamp style valve compressor with a 1/2 drive socket jamed in it but that only seems to work one a few valves i was wondering what the proper valve spring compressor is and how i can get ahold of one
This type of valve set up is a real pain, there will be a special factory tool to do this, as you have found out there is no easy way to do it, i am unsure if there is a readily available after market compressor that will do the job, may be contact a head repairer and see what they use.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
