Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Gmc Envoy Heater B...
Auto Repair2000 Toyota Camry Check...
Auto Repair1997 Nissan Maxima No S...
Auto Repair1993 Dodge Stealth Clutch
Auto Repair1997 Chevy Truck Hard S...
Auto Repair2000 Mercury Mountaineer...
Auto Repair2000 Ford Windstar Spar...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Dodge Durango power seering pump
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Nov 18, 2008 4:03 pm
By brandon jones, New to the forum
Give Feedback | Votes: 0
Steering problem
1999 Dodge Durango 6 cyl Two Wheel Drive Automatic
how do i replace a power steering pump on this vehicle
Find a car repair manual for your Dodge Durango Repair Question.
Posted at Tue Nov 18, 2008 11:43 pm
By bluelightnin6, Moderator
Reputation: 62.4Reputation: 62.4Reputation: 62.4 (62) Give Feedback | Votes: 4
No unusual procedures are required. Note any sensor wiring and vacuum lines at the pump. Bracket design varies depending on model and equipment fitted and may require removal or adjacent components for access.
REMOVAL:
Remove the pump drive belt.
Place a drip pan beneath the power steering pump and disconnect the hoses. Cap the hose ends.
Remove the power steering pressure switch connector and remove the pressure line from the bottom of the pump, if fitted. Remove the oil cooler mounting bolt from the pump bracket, if fitted.
Remove the pump and/or bracket mounting bolts.
INSTALLATION:
Reverse the removal procedure. Torque specs are as follows:
Bracket-to-pump = 35 ft. lbs. (47 Nm)
Bracket-to-engine = 30 ft. lbs. (41 Nm)
Rear bracket-to-front bracket (8.0L) = 18 ft. lbs. (24 Nm)
Lines = 25 ft. lbs. (35 Nm)
Refill the reservoir with power steering fluid and carry out the "Initial Operation" procedure.
INITIAL OPERATION
This procedure should be carried out whenever the power steering pump lines have been disconnected.
Turn the steering wheel all the way to the left.
Add fluid to bring the level up to the proper level and let the fluid settle for at least two minutes.
Raise the front wheels off the ground.
Slowly turn the steering wheel lock–to–lock 20 times with the engine OFF.
NOTE
On vehicles with long return lines or oil coolers, turn the wheel 40 times.
Start the engine. Check level and add fluid, if necessary.
Lower the front wheels and let the engine idle for two minutes.
Turn the steering wheel in both directions and verify power assist and quiet operation of the pump.
If the fluid is extremely foamy or milky looking, allow the vehicle to stand for a few minutes and repeat the procedure.
WARNING
Do NOT run the engine for an extended period if foamy fluid is present. This may cause pump damage.
Hope this helped.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
