Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1999 Dodge Dakota V8 Four Wheel Drive Automatic 185,00 miles
My truck ran fine a day before, this morning i came out and it wouldn't start. It has gas, it has spark and the starter sounds fine. I put gas down the carb and still nothing. Any ideas?
Hi:
How did you check for spark? If you provided the fuel, it should at least try to start. Let me know exactly what you have done so I can help you determine the problem.
Hi:
If there is spark, we need to check for fuel pressure. Can you hear the fuel pum run for a second when you first turn on the key? Is there any way you could check the fuel pressure? Some parts stores will lend tools.
Also, have you tried using starting fluid to see if it will start?
Hi:
Is it hot where you are? If so (I'm jealous... I hate winter anymore) lol. If it's hot, it could be a vapor lock. If the car is running now, have the computer scanned for trouble codes. Most parts stores will do it for free, and it may identify the problem.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
