Posted at Sat Apr 26, 2008 8:25 pm |
By
gwedemeyer@ma.rr.com,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic 74000 miles
Most of the time speedo, odometer, fuel guage, temp guage, automatic door locks, seat belt warning, door ajar chimes, rear wiper do not work. If rear wiper is working when guages quit, it will continue to operate until ignition switch turned off or wiper switch turned off, then will not start again. Occasionally they come back to life and odometer is updated. When out, service engine light is on, but goes off after short time if guages begin working. Radio, heater, rear defogger, lights unaffected. Dealer engine analyzer indicates body control module malfunction, but salvage BCM had same problem. Dealer proposes replacing BCM and other parts totalling about $1000 not including labor and won't guarantee that it will fix the problem.
| Find a
repair manual for your Dodge Caravan Repair Question. |
By
Advertisment,
| Find a
Posted at Thu May 15, 2008 5:03 pm |
By
zstarch,
Likes cars! |
I had a problem with my 99CV recently. All the lights, dash, headlights, tail lights started flashing! I could stop it by putting the headlamp switch to high beam?! The window on the car had been left down slightly in a rain and the carpey t on drivers side was slightly damp. When the car dried out after the weekend, the problem went away! This stuff must be very poorly designed to be this vulnerable to humidity. Is yours getting damp somehow?
. | gwedemeyer@ma.rr.com wrote: | Electrical problem
Most of the time speedo, odometer, fuel guage, temp guage, automatic door locks, seat belt warning, door ajar chimes, rear wiper do not work. If rear wiper is working when guages quit, it will continue to operate until ignition switch turned off or wiper switch turned off, then will not start again. Occasionally they come back to life and odometer is updated. When out, service engine light is on, but goes off after short time if guages begin working. Radio, heater, rear defogger, lights unaffected. Dealer engine analyzer indicates body control module malfunction, but salvage BCM had same problem. Dealer proposes replacing BCM and other parts totalling about $1000 not including labor and won't guarantee that it will fix the problem. |
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
