Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Mitsubishi Lancer ...
Auto Repair1993 Ford Probe Engine ...
Auto Repair1992 Honda Accord Starter
Auto Repair2005 Chrysler Sebring J...
Auto Repair1993 Chevy Beretta Heat...
Auto Repair1999 Gmc Savana Wont St...
Auto Repair1995 Chevy Monte Carlo ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Dodge Caravan Need Assistance with no Assist
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Nov 18, 2008 9:23 am
By jbahaveolos, Have Donated
Give Feedback | Votes: 0
Steering problem
1999 Dodge Caravan 6 cyl All Wheel Drive Automatic 115000 miles
There is little or now power assist when steering at low rpm 750. Worse when truning to the right, then the left. Fine at higher RPM over 1000. Only slightly better when hot. No leaks. Fluid was not low, but was dirty until I swapped out half for new. Belt and new tensioner have about 50K miles on them, but there are no squeeking or grinding noises. Even when turning stop to stop. Moved into a new house a year and a half ago, and have to turn all the way to the right stop when pulling in and out of the garage. Which is 10 times a day. Did I just wear out the steering?
Find a car repair manual for your Dodge Caravan Repair Question.
Posted at Tue Nov 18, 2008 10:09 am
By Jacobandnickolas, Moderator
Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5Reputation: 199.5 (199) Give Feedback | Votes: 7
Hi:
If the fluid is full, the pump may be getting weak or the rack and pinion may be wearing out. Also, the RPM's seem a little low. In park, it should be around 1000 and in gear, 8 to 9 hundred. Maybe adjusting the base idle will help solve the problem cheaply.
Let me know if you have any other questions.
Posted at Tue Nov 18, 2008 11:35 am
My RPM numbers were close estimates. The van actually idols closer to the numbers you gave. 1k in park and between 8-900 in gear. If the pump is wearing out, Do you think that I could try a low viscosity fluid before seeing the dealer? The problem came on all of a sudden rather than over time.
Posted at Tue Nov 18, 2008 2:20 pm
Hi Again:
You know, I thought about your problem since I emailed you earlier. The more I think about it, the more I want to say readjust the PS belt. It may be a seperate belt from the serp on your van. Or, if it's a 3.8L it may not have a seperate belt. It's sounds like at a low RPM it the pulley may be sliping causing you touble. Also, make sure that the self adjuster is keeping enough tension on the belt. Let me know if it has the seperate belt. Also, let me know if this helps. Finally, if the belt has 50K on it, it's most likely due for replacement. The belt companies recommend if you have more than 3 cracks within an inch, it's due for replacement.
Let me know what you find.
Posted at Tue Nov 18, 2008 4:28 pm
One serp style belt runs everything. I was thinking belt too, but don't they squeal when slipping. Or is that more with v-style belts? Let me know. I looked at the belt but did not inspect it with a fine tooth comb. No cracks or chuncks missing on the section that I looked at. It is definately time for a new one especially if it might solve this problem. If I change it and it doesn't solve the problem, I would still be glad it's done. I have always had to replace the tensioner after replacing the belt. I must put too much presser on the tensioner and sprung the spring. I guess that's the plan for this weekend. I will let you know how I make out.
Posted at Tue Nov 18, 2008 5:52 pm
Hi:
Let me know. Belts can slip slightly and not make noise. I'm hoping that takes care of your problem.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
