Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1999 Dodge Avenger 6 cyl Two Wheel Drive Automatic 217000 miles
hi my car has a major oil leak which looks to be coming from timimg belt cover and my car is surging really bad and there is major heat coming in through floor board on drivers side. do you have any ideas
first of all , check all fluids including transmission. And the leak sounds like the crankshaft seal is shot and you may need a water pump. Is there any check engine lights on? If there are then take it to autozone for a free scan and come back with the codes
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
